HELP 1995 5.7 chevy suburban engine runs good then starts missing - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-09-2011, 07:34 AM
Did Your new computer fix the problem? My Brother has this exact problem and he has gone through 4 computers. His suburban was in the shop for 30 days and finally last night we towed it home. The mechanic supposedly tried everything.
  #17 (permalink)
Old 07-09-2011, 03:01 PM
T-bucket23's Avatar
Wiki Edits: 26
I have seen this issue a few times. It turned out to be a bad ground cable one the back of the engine. Is is a braided cable and they were rotted right off.
Chet
  #18 (permalink)
Old 06-24-2013, 04:13 PM
Having similar missing issue
After researching around, I wanted to know if changing the computer at the dealer solved the engine missing issue? I've been replacing parts and have run out of options other than distributor and computer. Thanks
  #19 (permalink)
Old 06-24-2013, 04:45 PM
jokerZ71's Avatar
Wrench Turner
You're gonna have to do some tuning after putting the stroker in.The added displacement is gonna drive the computer nuts & will most likely cause a lean condition.You will HAVE to have a chip burned for it to run anywhere near rite.You will also need to add an adjustable fuel psi regulator & raise your fuel psi.More than likely you may need to increase injector size also.
1995 suburban engine swap SBCfan04 Engine 2 07-17-2010 08:21 PM
1995 Suburban ABS light on SBCfan04 Suspension - Brakes - Steering 2 05-21-2008 10:23 PM
1995 suburban 1500 series 4by jtyler Suspension - Brakes - Steering 10 08-18-2007 06:56 PM
1995 suburban 1500 series 4by jtyler Suspension - Brakes - Steering 1 08-07-2007 07:42 PM
New Edelbrock engine dynos good but runs bad when in car. Quarter Flash Electrical 3 04-27-2006 02:35 PM
