Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - help with a 2 speed power glide tranny
Old 12-28-2012, 09:19 PM
junior stocker's Avatar
junior stocker junior stocker is offline
The ONLY way your "Powerglide" converter will work in a TH350/400 is IF it was made to be used with a TH input shaft modification for the Powerglide. A lot of drag racing Glide converters are these days. As far as the Glide to transfer case, I would think "someone" is doing this; try the puller/mud racer sites, and ask that question there. Gear vendors makes an overdrive adapter for the Powerglide, and that involves a shorter output shaft for the Glide; you'd need the same sort of shorter output shaft to make this work. Butch from the U.S.A./junior stocker.
The Following User Says Thank You to junior stocker For This Useful Post:
ctr2001inc (12-29-2012)
