help with a 2 speed power glide tranny - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-27-2012, 04:00 PM
Hello Folks my name is Rich from Canada, I recently purchased a motor that came with a built 2 speed power glide tranny built for 1000hp. I would like to use it in my mud bogger I a building. Is there any way to hook it to a np 205 transfer case through adapter or something, also will the stall from the powerglide work in a turbo 350 chevy tranny. Thanks for the advice.
Old 12-27-2012, 09:13 PM
Powerglide
I do not know of any company that makes an adapter kit to mate the Powerglide to a transfer-case of any make. I would think for a 4WDR mud truck you would be better off selling the glide to a drag racer and building a T-350 or T-400 for your application. If you have your heart set on using the Glide you would have to use a divorced transfer case with a short drive shaft or a coupler shaft from the Glide to the T-case. It can be done, but is cost prohibitive.
The Following User Says Thank You to Studebaker For This Useful Post:
ctr2001inc (12-28-2012)
Old 12-28-2012, 08:19 PM
junior stocker's Avatar
The ONLY way your "Powerglide" converter will work in a TH350/400 is IF it was made to be used with a TH input shaft modification for the Powerglide. A lot of drag racing Glide converters are these days. As far as the Glide to transfer case, I would think "someone" is doing this; try the puller/mud racer sites, and ask that question there. Gear vendors makes an overdrive adapter for the Powerglide, and that involves a shorter output shaft for the Glide; you'd need the same sort of shorter output shaft to make this work. Butch from the U.S.A./junior stocker.
The Following User Says Thank You to junior stocker For This Useful Post:
ctr2001inc (12-29-2012)
2 speed power glide bolt on? robl66 Engine 8 07-29-2011 04:50 PM
To Power Glide, Or not to Power Glide 68Elcamino Transmission - Rearend 3 06-25-2010 05:59 AM
Power Glide jmbjs Transmission - Rearend 7 04-21-2007 01:30 AM
power glide? nitro_baller4692 Transmission - Rearend 1 09-24-2006 04:19 PM
2 speed power glide APACHEMAN Transmission - Rearend 3 07-14-2003 07:41 AM
