Biggest problem with most of the Linc. rears are 5 on 5 bolt circle,with big hub whole and odd offset from flange to bearing shoulder on axle.Most Exsp. kits need 2.500 offset with 1.771 center hub.If you can find any,I'd start with '72-about '76 Linc.Continental,(coil spring rear) might fit without any mods.
later Mark ! !
Mid 70's Mark's had an option for a 9 3 / 8 Disc brake rear end (4 wheel disc brakes ) You might be able to measure for fit then gather the Factory parts, rearend , e brake cables, hoses. master cyl . hard lines, Combination vlave and put it all in. brake pedal. I don't know how much you would need.
