Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help with 305 crankshaft
Old 02-20-2013, 07:20 PM
morcey2 morcey2 is offline
Is the counterweight that you see part of the mounting flange at the back of the crank? 2-piece rear main seal 305s are all internally balanced and that counterweight that you see is part of that balance.
Have you pulled the flexplate/flywheel off the old engine and compared them directly?
