-   -   Help with 305 crankshaft (http://www.hotrodders.com/forum/help-305-crankshaft-229799.html)
kiaser001 02-20-2013 06:06 PM
Hi all,
I just bought a 1980 K5 Blazer. It has a bad 305 in it and came with a rebuilt 305. I pulled the engine and noticed that the crankshafts were different. I researched and found out that there are 2 piece and 1 piece crankshafts. I determined that the new engine has a 2 piece crankshaft with what looks like a counterweight on the outside of the engine. Also the casting numbers says that this engine came from a 1980-1984 camaro,nova.
My question is if I use the new engine with the two piece seal and I buy a flywheel from autozone. due I have to worry about balancing the flywheel?
morcey2 02-20-2013 07:20 PM
Is the counterweight that you see part of the mounting flange at the back of the crank? 2-piece rear main seal 305s are all internally balanced and that counterweight that you see is part of that balance.
Have you pulled the flexplate/flywheel off the old engine and compared them directly?
Matt
kiaser001 02-20-2013 09:28 PM
I have compared the cranks and they are different. I upload some pics in the members gallery if you search my name they are the only two pics I have uploaded.
So would a flywheel from autozone be ok?
morcey2 02-20-2013 09:31 PM
http://i113.photobucket.com/albums/n...buildcrank.jpg
If that shows up, the left is a one piece seal. The right is a two piece (pre-87) crank. If it's the one on the right, a standard zero-balance flywheel will work. I think "zero-balance" is the phrase I'm looking for.:confused:
Matt
morcey2 02-20-2013 09:41 PM
Found the pics. Yes, an autozone flywheel for a pre-87 small block would work, as long as it's not a 400 engine flywheel.
Matt
vinniekq2 02-20-2013 09:50 PM
its apart,balance everything,lol.
kiaser001 02-20-2013 10:00 PM
thanks for taking a look at pictures still have to figure out how to upload them I read the tutorial but still think I'm doing something wrong but I appreciate the advice.
morcey2 02-20-2013 10:17 PM
That's crazy talk!!
bondo 02-21-2013 07:11 AM
Originally Posted by kiaser001 (Post 1648590)
Hi all,
Ayuh,.... They're both considered Internally balanced motors, 'n the bolt pattern is different on the respective flywheels so's ya can't get it wrong...
If ya buy a flywheel for a 305, 2 piece rear main seal crankshaft, Yes, it'll be properly balanced...
