Help with 305 HO heads!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2013, 08:21 PM
Hi, guys this is my 1st post on here and I have a Question. I just got a set of 305 HO heads: 14014416 and #624. They are good heads but I would like to know if they will work on a 350 bored 40 over with flat tops. Also need the best street cam and lifters for it. The motor is going in my 1927 model A Rat Rod so it is just a cruiser not a racer. It has 373s in the rearend and a 2 speed power glide trans and we drive it on the hiway quite a bit. Like I said its not a race car just a strong cruiser. All your ideas are greatly appreciated!! Chasman
Old 04-14-2013, 09:45 PM
vinniekq2's Avatar
chasman,welcome. 3.73 gears? hope the tires are 30 plus inches tall for hiway use.
Old 04-16-2013, 01:33 AM
lhmurphy's Avatar
I ran a Comp 268HE cam .454/.454 lift on a 350 with 416 heads/64cc and flat top pistons and was happy with it!
Old 04-16-2013, 09:00 AM
Why do you say I would need 30"+ tires?? I have ran 373s in several of my cars with great luck and still had performance. I am however considering going to a TH350 OR 400!!
Old 04-16-2013, 09:06 AM
Why do you say I need to run 30"+ tires? I have used 373s in many of my street cars with great luck and performance!! I am however considering a TH350 or 400 instead of the 2 speed power glide.
Old 04-16-2013, 04:24 PM
You will have great performance, just that the revs will be a bit high, esp. since you "drive it on the hiway quite a bit." And to cruise at 70mph requires 3300rpm, and thats not figuring any torque converter slippage at all. Just taching a too much rpm for decent fuel economy ofr mainly highway use.
26" tire, 1:1 drive, 3.73 gear, 60 mph=2900rpm, 70mph=3300rpm, 80mph=2800rpm
swap to 30" tires=60mph=2700rpm, 70mph=2900rpm, 80mph=3350rpm
Obvioulsy swapping to a th-350 or th-400 wont make a difference to cruise rpm. A th-350C with lockup would bring rpm down 150rpm or so.
peace
Hog
The Following User Says Thank You to Hogg For This Useful Post:
vinniekq2 (04-16-2013)
Old 04-16-2013, 04:48 PM
spinn's Avatar
I run 28" tire with 3.73 through a th350c. In lockup it is under 2800rpm at 60mph. It is a daily driver.
Old 04-16-2013, 04:54 PM
Banned
For a daily driver the rpm is a bit high for a fun weekend toy you'll be fine. With those heads and gears I'd go with a 268 cam and swap in a 700r4 when you get the time and money.
Old 04-16-2013, 08:14 PM
vinniekq2's Avatar
I run .82 over drive and 60 mph is just over 2,000 rpm. Im using 27 1/2 tall tires.I have run as high as 5.57 gears on a street car.If you like the engine at higher RPMs then 3.73 is your cruising gears. A mild engine is nicer imo at 2k.
Old 04-18-2013, 08:29 PM
Well I am running 28" tall tires and at 65 mph its running right at 2700 rpm's. It seems to do fine. I know that the rpm's are sort of high but it runs and sounds great going down the road. I don't drive it everyday, mostly on weekends, weather permitting of course!! We have a blast with it and needless to say it gets tons of looks and comments. Thanks for the input all. Chas
041 heads vs 305 HO heads mrwilson3130 Engine 0 12-15-2012 12:20 PM
305 heads or 350 heads on sbc 355 ryan v Engine 5 09-20-2012 10:21 AM
305 "416" heads on 305 .40 over...What would the comp ratio be? GMMAN Hotrodding Basics 6 03-24-2011 11:41 AM
283 w/305 heads. 305 head gasket? malibu65ss Engine 2 01-16-2003 02:07 PM
350 heads or 305 H.O. heads????? crshrmn3 Engine 3 08-25-2002 08:51 PM
