help with 305 hp - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2011, 11:40 PM
help with 305 hp
I have an 85 el camino. I bought some accesories and was wondering howmuch HP I would gain, and how I could get more? 270 cam, long heddman headers (straight pipes, no cats) new timing chain, .030 bored, rpm air gap intake manifold, lifters, perform 1.5 rockers, valve springs, edelbrock 4 barrel carb, and I'm getting a valve job on the heads. and I'm thinking about buying some iridium spark plugs. Also I will be putting in a 700r4.
Old 04-25-2011, 06:56 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
With that cam the best mod you can make is a change in gear ratio. The TH700R4 has a deep first gear and that will help a lot- but until then, expect this thing to be sluggish until it gets up on the cam.
Old 04-25-2011, 08:30 AM
a set of 305 vortec heads and matching intake would make big gains in airflow,compression and match your cam much better.
a 2500 stall conv and 350 rear gear ratio would really wake it up
with your combo your going to gain approx 30hp
with the combo i mentioned i bet you get 80hp
do yourself and ppl around you a favor give up 5 of those hp and weld some cats in it please
Old 04-25-2011, 02:49 PM
thanks cobalt 327
What kind of gears should I look into?
Old 04-25-2011, 04:02 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You should start by seeing what the rear gear is now. A lot depends on how you use the vehicle for one thing. If you do a lot of highway driving, you'd want to stay reasonable, like around 3.23-3.42 range. If you are more an around town driver, 3.73's would work well.
But that's why an OD AT works so well- you can have a steep rear gear, yet the OD will pull it right on down to a highway gear.
Old 04-26-2011, 08:28 PM
spinn's Avatar
My 305 went , Vortec heads , perfrmr cam , intake , QJet , headers with DMturbos muffs, electric fan , 3.73 with 28" tire , TH350C lock up on a switch. Great build, powerband for street, needs no stall . Busy , but driveable on the highway, 65 at 2850rpm. Problem, the 85 GM truck weighs about 4800lbs. 15.7 run at 87 mph. 17 MPG at 65 cruise at one speed no hills.
