Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help on a 305's timing
Old 04-26-2006, 11:43 PM
Alf P Alf P is offline
I can't tell you why the dots are changing positions but i might be able to help you on something else. when you drop in the distributor bring #1 to TDC, then point the rotor (the flat part not the springy part) at number #1 on the cap, not to the number one cylinder.
