Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help on a 305's timing
Old 04-27-2006, 08:27 PM
killerformula's Avatar
killerformula killerformula is offline
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
Originally Posted by jcmmcote
thanks Frisco, That is exactly what i needed to know. It fired up tonight. Got another Q. for you if you don't mind. What would make the spark plugs have oil on them when you pull them out and look. Do you think my intake gaskets haven't sealed yet? Definetly appreciate the other answer.
depends on how much oil, but that's common until the motor has a few miles on it. Rings should seat in the first few minutes of running with molly rings, but I find that most motors take a couple hundred miles to start feeling just right.
K
