help 32 roadster - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2013, 04:56 AM
help 32 roadster
I want to finsh off the area around seat where the body meets the inside of car not sure what this spot is called. I have seen some with what i think is welting and then some with what i would call for lack of words a pillow around it any pic or thoughts would be great
Old 05-25-2013, 07:34 AM
DanTwoLakes's Avatar
Wiki Edits: 22
I'm not sure what you are talking about, can you post a picture?
Old 05-25-2013, 07:44 AM
really donot know how to post pics it is the curve that goes around from one door to the other behind the seat. sometimes they are wood topped and other have a u shaped pilllow going around i will see if i can load pics later
Old 05-25-2013, 09:43 AM
Wiki Edits: 22
O.K., I got it now. This is a roadster and you want to put upholstery over the area from the passenger door to the driver's door. I call it a padded collar. There's a dozen ways to do it, what do you want it to look like?
Old 05-25-2013, 09:55 AM
i like the look of welting around it and the plan on going tuck and roll to match the rest of the inside thanks
Old 05-25-2013, 10:12 AM
Wiki Edits: 22
Do you want real tuck and roll, or just sewn in pleats?
Old 05-25-2013, 11:00 AM
the rest of car is sewen in pleats jus need to do something with the collar as yo called and then down behind the seat
Old 05-25-2013, 11:25 AM
Wiki Edits: 22
The first thing you need to do is attach some strips to the inside and outside of the collar area to attach the pleated fabric to. This can be wood or plastic if that's more available to you. It only needs to be 1/2" to 3/4" thick. You can cut it in narrow pieces like 2" wide on the curved areas. It needs to be about 4" top to bottom on the outside and inside. Once that is in place, you need to pad the whole collar with foam, about 1 1/2" thick and relatively firm. Once the padding is on, you attach the pleated fabric to the wood at the bottom of edge underneath on the outside and pull the pleated fabric and foam over the top and attach it to the bottom edge of the wood on the inside. You will have to make allowances in the corners of the pleated fabric for the turn you will be making. The pleated fabric will have to be narrower on the inside and wider on the outside to make the turns. Once you have all that done, you can glue some pleated fabric to the inside wall below the collar and down to the floor.
Old 05-26-2013, 04:30 AM
i think I got it different than what you said but the steps worked to make it we will try and post some pic later thanks
Roadster swvalcon Hotrodders' Lounge 4 01-23-2013 04:45 PM
32 Roadster maddchopper Introduce Yourself 1 04-18-2011 04:37 PM
32 roadster ITSC Introduce Yourself 1 08-28-2007 08:50 PM
28/29 vs. 32 roadster socalroadster Hotrodding Basics 21 06-10-2006 04:13 PM
Different roadster OneMoreTime Hotrodders' Lounge 14 01-15-2006 12:29 AM
