Help! 327 coughs when I shift to 3rd (full load) - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-28-2006, 03:30 AM
57 Chevy's Avatar
Daryl
Location: Montana, now Arizona.Now Colorado. Wish I was back in Montana
Most Chevy's like 38 degrees total MECHANICAL advance. Don't worry about the vacuum total. That only comes in at cruise/ no load driving for better gas mileage.
If your plugs are still set at .35, you can open them up a little to take advantage of the hotter HEI.
Just my 2 cents.
  #17 (permalink)
Old 03-28-2006, 08:18 AM
Glad to hear you got it figured out.
I had some Edelbrock carbs in the past and the main problems that I had was sticky throttle activation due the terrible accelerator pump design and vapor locking in the summer due to the wrong carb material.
Yes, don't worry so much about the total timing from the vacuum advance. The vacuum advance should shut down when the vacuum drops at WOT at higher rpms. As long as it doesn't detonate while the vacuum advance is on in the mid range rpms then use it for better mpg and throttle response.
Transmission won't shift into 3rd gear. Why????? CCR Transmission - Rearend 7 02-03-2005 07:39 PM
700r4 wont shift into 3rd BIG DIXIE Transmission - Rearend 1 01-12-2005 08:04 PM
700r4 won't shift into 3rd????? HELP!!!! ConvertablePickupGuy Transmission - Rearend 7 02-14-2004 06:44 AM
Tranny shift problems. chevcamz28newbie Transmission - Rearend 6 08-09-2003 06:52 PM
My AOD, the full story mustang66maniac Transmission - Rearend 26 01-30-2003 05:38 AM
