Help with 35 Chevy Standard 4 door - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2011, 10:07 PM
My goal is to build an old school hotrod. I want a straight axle, not sure what will work. I like the ones that I see in a lot of 32-34 fords. As far as the rear end I have heard that a 67 nova will fit it or a 9in Ford . I am doing away with all of the wood and putting in steel tubing. I am having a hard time with the rocker panel area because they are gone. As for the engine, I was thinking a 350 or a 283. I was given a 283 but I have never supped one up before. I don't know much about them. The trans I am thinking a Muncie 4 speed or Borgs Warner. Any help, tips or ideas will be greatly appreciated. I am kinda beating my head against a wall here.......WILL
Old 09-15-2011, 07:37 AM
delawarebill's Avatar
'35 chebby
first not all 9" rears are a drop in project.. and for a sbc i can easily use a 8".. and they are not drop in's either..u'll need to contact the verdor of a straight axle to see what it fits and how. do u have the car yet ?????
Old 09-15-2011, 01:18 PM
Yes a have the car.
Old 09-15-2011, 02:56 PM
Take note that the front axle on your car is "like" the ones on the Fords but it uses two parallal springs instead of one transverse spring the Ford has.
Old 09-17-2011, 09:12 PM
transverse vs parallel
can I use the transverse under my car with a little modification? I like the way that looks instead of the parallel.
Old 09-17-2011, 11:03 PM
It isn't "easy" but sure it can be done and is often done on GMs which originally came with parallel leaves.
rocker panels for 35 chevy standard gearhead35 Body - Exterior 9 05-28-2011 08:59 PM
question regarding 35 Chevy Standard gearhead35 Hotrodding Basics 3 04-02-2011 03:51 AM
34-35 Chevy standard suspension ideas. jcarter Suspension - Brakes - Steering 1 09-27-2009 08:47 PM
my 36 Chevy 2 door standard Coach project Wolfman36 Introduce Yourself 7 02-10-2009 11:16 AM
Is it hard to tap Chevy SB for standard starter? shockers69 Engine 4 04-22-2006 10:47 PM
