help....350 actin like a biotch..ha ha - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2005, 07:53 PM
downtempoking's Avatar
Downtempoking
Alright so my 73 El Camino is actin like a biotch ok so the engine is shakin..... and some moisture in the left tailpipe no smoke ran fine for last six months no isuues till now...oh and i gotta replace the trans oil pan gasket....so any help from the rodding gods is most gratefull....
Camden
Old 07-13-2005, 08:45 PM
TWOPLYM's Avatar
New Member
info
yup i think we need more info
Old 07-13-2005, 09:00 PM
Downtempoking
more info...
Ok so after takin it out the other day i parked shut her off and she kinda kept runnin for like 3 sec then shut off... now the engine is shakin tonight i started her up like majik... and the whole car was shaking? I have a leak in the trans oil pan gasket i am fixing that mon.... it was in park so i dont think it was the trans.... and it has fluid well some trans fluid in it....i was also low a quart of oil so i added that and checked the exhaust to see if it was smokin or anything no smoke but i put my hand on the left hand side and it was moist....i dont know how much more info you need i got the car 6 months ago...and as it always is ...things kinda wear out .....anyways...it all happened on that same day? May be a motor mount, or timimng or miss fires... i dont know.... I am a newby so help is soo sooo welcome
thanks,
Cam
Old 07-13-2005, 09:26 PM
you have got to take a look at it! but if it kept running for 3 seconds after you turned it off, it aint your motor mount! its not the tranny fluid or your 1 quart of low oil. check your timing. check to see if your distributor needs to be bolted down better. it could just be a little loose and giving you timing problems.
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
Why not a 350 sbc? bowtieorbust Engine 29 09-05-2008 09:43 AM
Where is the best place to find a 350 engine Andrew7dg Engine 8 10-20-2005 04:28 PM
destroking a 350 griffinzein Engine 107 12-08-2004 07:45 AM
305 vs. 350 question DesertPanel General Rodding Tech 4 10-16-2003 08:19 PM
