Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help With 406 Engine Build
  #36 (permalink)
Old 09-03-2008, 04:16 PM
Olds86 Olds86 is offline
How can I tell if I have sufficient breather capacity? That I'm not really sure of, and I don't know know to check it either. The ring problem I've heard a couple of times, but I've never put anything less the 93 in the car and even mix in a lil racing gas every now and then. I do have smoking out of the tailpipes also, nothing at idle but quite a bit at WOT. Engine isn't tapping, knocking or making any other strange sounds, and runs really strong. I've also been told that the smoking out of the tailpipes could be caused by oil being sucked into the pvc as well, any possible truth to that?
