Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help With 406 Engine Build
  #40 (permalink)
Old 09-04-2008, 07:02 PM
Olds86 Olds86 is offline
Well I pulled the pvc to see if it made any difference as far as the dipstick, but it was still sitting off the the tube a bit, but I did look down inside the valve covers and the baffles really do look a lil tight, I'm going to try opening those up a bit and giving it another try. I've also been reading up on the leak down test and how to perform one as well that you referenced earlier. I'm really hoping their isn't a problem w/the rings.... I was trying to do little things first before jumping into this engine thing, didn't want to jump in the deep end first. With having to pull and re-ring the engine.
