Help 454 gen 5 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2005, 03:39 PM
New Member
Help 454 gen 5
Hi ive just pulled the cam from my gen 5 454 engine to change it for something better. surprised to find no cam thrust plate! however sprocket alignment looks ok and cam gear hasnt been touching the front cover .my book only mentions the gen 6 engine,with roller cam, which does have a thrust plate.My question. Am i missing a thrust plate or does the gen 5 with flat tappet cam not have one? PS ive never had this engine running ,im building it to replace my current engine !
Old 05-20-2005, 03:59 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Flat tappets don't need one. They are self centering.
Old 05-20-2005, 05:29 PM
New Member
help 454 gen5
thanks, is there not a tendancy for the cam to come forward under heavy braking for instance? i know all the small blocks have a thrust plate! but this is the first Big block ive looked at .
Old 05-20-2005, 06:23 PM
NorthStar's Avatar
A flat tappet cam is ground so the lobe taper causes cam to not go forwards.
Roller cams are ground with no taper thats why they need a thrust plate.
Old 05-21-2005, 12:06 AM
New Member
454 gen 5
Im installing a double row chain which has very little clearance,fits ok and dos,nt touch the front cover when tried with no gasket,but very close Thanks for your replies Frank
Old 05-21-2005, 06:28 PM
Hey, I like that T/A in your album. Looks nice.
Squeezing a little more power out of my 454 RObs71Nova Engine 8 05-21-2005 04:38 PM
454 Gen V Valve Settings JDHBAJA Engine 2 02-04-2005 07:01 PM
454 or 427 for 70 Chevelle? f100beatertruck Engine 3 11-25-2003 06:29 PM
Seems Best way to Buy a 454 BB is to Buy a Truck Auto-Part Engine 3 11-15-2003 05:23 AM
