help 49-50 poncho rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2005, 10:32 AM
Sucio 50's Avatar
New Member
the guy i bought the car from said he never change the rear but the rear thats on there dosent look original it look more like a 9" ford can someone please post a picture of a 49-50 poncho rear end please
Old 03-22-2005, 12:08 PM
speedfreak2's Avatar
WrenchingAce
Sounds like you have the GM 9.3 "C" rearend. Looks like the ford nine inch but bigger. It should have a 13 spline pinion gear. Mark Williams is the best place to get parts for that particular unit.
Old 03-22-2005, 02:36 PM
Sucio 50's Avatar
New Member
im going to post a pic of it
Old 03-22-2005, 04:26 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
You have a Hotchkiss style axle in that car, it looks similar to a Ford 9 inch which is the most popular Hotchkiss style axle.
The type of axle you are "thinking" should be in there is called a Salisbury axle, with the non removeable gearset and sheetmetal cover.
Here is a link to some brief info and a pic.
This link is backed out one step from the above link, with a similar description to mine.
Old 03-23-2005, 02:23 AM
rear end
M-M , I'll have to disagree with you on the non removable gear. I used these rears in my early oval track cars. They were very tough and if you could find a standered shift Pontiack they were 4.30 gears on the old ones and 4.11 later. I think they would interchange from at least as far back as 38 to 54. As best i can remember the bolt patern was round where the Ford is oval. KEITH
Old 03-23-2005, 05:45 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
Only passing information I found on the internet.
If you have anything more to share, by all means we welcome you to do so.
I still have to agree that by his description he has a hotchkiss style axle.
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 09:03 AM
S-10/Camaro Rear End slaveforthewave Transmission - Rearend 7 02-20-2006 01:44 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
anyone running 700r4 with 3.55or 3.77 rear end? 37 chevy Transmission - Rearend 7 01-06-2003 06:34 AM
Rear end swap problems datsun dale Transmission - Rearend 1 12-17-2002 10:50 PM
