Run a jumper wire from the F (field) terminal to ground.
This puts the generator into full field mod. Check the ammeter to see if it goes to full charge. The engine speed will need to be increased to get full charge. There are many other things that can cause poor charging. vicrod |
P.S. do I remove the regulator wire before jumping or leave everything connected? Last edited by Greg T; 08-05-2011 at 02:12 PM. |
The regulator wire can be connected.
When you jumper across the regulator you are shunting the generator field control resistors. vicrod |
Got it. So the regulator is actually regulating field current. By grounding the field terminal of the generator the fields get full battery current and should run wild. I can't believe how much I have forgotten over the years. This used to be childs play for me. Especially these B circuits.
| 47 chrysler | gary schwendemann | Suspension - Brakes - Steering | 1 | 01-06-2010 04:23 PM |
| know anything about the 79 chrysler 300? | rossk | Hotrodders' Lounge | 5 | 10-31-2009 10:26 PM |
| ron the chrysler fan | ron stout | Introduce Yourself | 2 | 06-12-2007 05:40 AM |
| chrysler BB | chevellesrule71 | Engine | 2 | 12-29-2003 05:18 PM |
| Chrysler 400 BB help please | dj_xtreme | Engine | 2 | 09-23-2003 10:26 AM |
