Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help with 68 camaro emergency brake install disc brake
Old 02-13-2010, 07:56 AM
Frisco's Avatar
Frisco Frisco is offline
Glad To Be Here
Originally Posted by jdp2603
Thanks Frisco for replying. No cpp didnt the shop i had it at did but i figured if the brackets arent there I can pick up new ones. yes if you can post instructions that would help out a great deal
If you could post a picture of the rear caliper it would help to assist you as to what may be required to install the parking brake cables.
I have attached the instructions as to how to adjust the GM rear calipers that have the built in cam operated parking brake. If this is the style of rear calipers you have, these instructions will help.
