help, 700 R killin me - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2003, 06:14 PM
Unhappy help, 700 R killin me
This is the third 700 R i've put in my 92 caprice. It shifts from 1 to 2 but then neutralizes and you have to bring the car to a complete stop before it will pick up again. Drives fine in low (2) on the dash but won't move in (1) on the dash. Is it gone ? Is there a machine I can put it on to tellll me if it's gone? I just started putting in transmissions, so I'm inexperienced and can not give proper diagnosis by the symptoms, please help.
Old 02-03-2003, 10:47 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Post
Pretty much anytime you get a tranny problem not related to low fluid problems you can expect to rebiuld it. By the time you dissasemble for inspection than you're already far enough in to warrant the cost. Hate to give the bad new's, but that's the way the rust crumbles.
Old 02-03-2003, 02:02 PM
ronb's Avatar
Post
Are you setting the TV cable correctly? if you have gone through 3 of them you must be doing somthing wrong? are you rebuilding yourself?
