Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-01-2005, 02:44 AM
TWD TWD is offline
Help
I would like to know all of the adjustments or add ons you can do for better horsepower in a 350 small block. From top end to bottom end.
if someone could help me out that would be awsome!!
Old 11-01-2005, 10:27 AM
Tazz
I'll play this game.....
To Begin with start with a GOOD set of heads and aluminum intake and headers......
Who will be next to help out this young Dude?
Tazz
Old 11-01-2005, 07:04 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
If your on a "Bare Bones" budget...
and don't want to pull the engine totally down to gain some modest HP..
Try, First a total NEW (whether or not it needs it) Tune up...Plugs, wires cap, coil, module...Then do the adjustments on the carb..If you can't get responses or minimal response from it rebuild or replace it.., Then go to a good set of headers, larger exhaust pipes and low flow mufflers...add a high volume COOL air airfilter, and possibly a mild cam..
That will give you results you will notice for minimum bucks..
For a total upgrade you are only limited by the 3 "T's"...
Time...
Talent...
Treasury..
Doc
Old 11-01-2005, 07:24 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
My Dad used to say....Speed costs money! Now how fast do you want to go?
Old 11-02-2005, 05:46 PM
TWD TWD is offline
Thanks man
Tazz
Thanks...What would be the best fuel system to go with that has good gas mileage and horse power?
TWD
