Help! 77 Chevy motor swap questions! - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-04-2010, 11:02 AM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
Originally Posted by CokeZero
My plans for it so far is to get a motor and tranny in it just to be able to drive it. (2wd) then a little later start adding to make it back to a 4x4 when I can.
Well if that's all you want to do , just find a carbureted 350 engine and tranny from just about any non-computer chevy or GMC full size 2wd pickup or full size car , Impala , Caprice and just run stock manifolds for a 73 to 86 pickup and stock headpipes should bolt right up . Should just be a basic setup . Driveshaft will depend on what tranny comes out of . May have to have one made up but not a big deal .
  #17 (permalink)
Old 08-04-2010, 11:22 AM
CokeZero's Avatar
awesome good to finally hear a little good news on top of all the bad. I'm just hoping I can reconnect everything lol.
Plus I have no idea how im gonna drop a motor in there. I'm 6ft and this truck is way taller than me. Its alot bigger than what that pic shows. hood has to be atleast 6'4''
I dunno how id even jack this thing up if i had to lol
  #18 (permalink)
Old 08-04-2010, 11:45 AM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Wow . Be careful when you do get it running . It is not going to be the most stable thing on the road being that high . Let us know how it turns out . I'd like to see it in running condition .
  #19 (permalink)
Old 08-04-2010, 11:51 AM
CokeZero's Avatar
Here is a vid I just took, 1st time getting to look at it really. i had to leave for work right after it was delivered. was hard to get the camera over the hood so i just went under lol.
http://www.youtube.com/watch?v=m-JB8HCE1cU
  #20 (permalink)
Old 08-04-2010, 12:02 PM
poncho62's Avatar
Wiki Edits: 5
I suggest that you dont do that......It is going to drive real weird with that front end with no 4x4......
Looking at your video, that trans and transfer case is not what belongs in that truck from the factory...
My thought would be to part this truck out and buy something that is a bit more together to drive.....just my opinion
  #21 (permalink)
Old 08-04-2010, 12:07 PM
CokeZero's Avatar
^^ trans is a 4 speed with no bellhousing or clutch. I'm wanting an auto anyway.
  #22 (permalink)
Old 08-04-2010, 03:08 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
YIKES ! ! After seeing this video I'd say you bought yourself a cobbled together mess that belongs in the boneyard. Sorry , but personally I would not mess with it . That is NOT the trans and transfercase that came in that truck . Don't know anything else about it , but I don't get a good feeling . I feel bad for you that you bought this sight unseen . Time to get rid of it !
  #23 (permalink)
Old 08-04-2010, 04:30 PM
CZ,
You said in one of your postings that you want to put it together as a 2wd for now then switch it back to 4wd later.
This in my opinion is a very bad idea. You will get parts set for the two wheel built or by from a wrecked truck that will not be used in the 4 wheel drive set-up. Like the rear drive-shaft. You will have one made for the 2wd application which will need to be shortened when you go back to the 4wd. Just using up time and your money.
Don't get so excited that you start throwing money and time at this thing.
Scholman
  #24 (permalink)
Old 08-04-2010, 04:36 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
Originally Posted by scholman
CZ,
Scholman
Like I said . I wouldn't fool with it after seeing the video. It would also need a different tailshaft for the transmission along with the married transfer case to make it right . It is hard to say what trans and tranfercase it has now . Looks like it could be an early Dodge with the divorced transfercase .
  #25 (permalink)
Old 08-04-2010, 04:49 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
That looks like a pretty typical mud truck around here....they are right, that ISN'T the transfer case that came in that truck, but I believe it's stronger, looks like a Dana 60 rear, probably also upgraded, and IIRC, the stock front axle is a driver's side driveshaft, yours is passenger, which would leave you either stuck with that transfer case, or swapping front axles. Looks like a hell of a mud truck project, for sure, it's got a lot of good pieces, but probably won't make a good street truck.
  #26 (permalink)
Old 08-04-2010, 04:50 PM
CZ,
I watched your video. Next time how about a little talk as to what you are looking at and what you plan for this thing.
This truck is NOT STOCK!!! I think this was made to rock climb and do some heavy-duty off road antics. Fun to do but not a daily driver.
I go back to the drive shaft you will need to have made. It will need to be at least 8 feet long so it will need a center carrier bearing. Then when you change back to 4wd the shaft will need to be made shorter and reconnect to the transfer case.
While I am typing this response I think your best bet would be to find the running gear from another truck.
The other problem you are going to have is the steering set-up. I did not see a pitman arm on the steering box and not a single tie-rod or anything to get this truck back on the road in the front end.
Hey it is a GREAT project truck if you are into off roading and rock climbing. But you need to know more than just part replacement. You need to do TONS of welding and fabricating. Be sure before you get so deep into this project you can't get out later on when things get very expensive.
Scholman(retired)
  #27 (permalink)
Old 08-04-2010, 04:58 PM
adantessr's Avatar
'23 T-Bucket Pickup
Wiki Edits: 3
CZ,
Scholman(retired)
DITTO ! adantessr (also retired)
  #28 (permalink)
Old 08-04-2010, 05:00 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Lot of work there ahead of yourself, But i have seen worse but it's going to take a bundle of cash and alot of work to do it right where you can rally enjoy it.JMO And you are going to have to have a new drive shaft made also
ex-specially if you leave out the T/C. Just thought i would throw that out there not a expensive thing but your going to need one. Among other things.
IMHO i wouldn't fool with it if i wasen't going to do it safe and correct.JMO
Cole
  #29 (permalink)
Old 08-04-2010, 05:03 PM
Rickracer's Avatar
There are probably a bunch of guys looking for just such a project for a rock crawler or mud truck, but if you plan to make it a real street truck, it probably won't be worth it.
  #30 (permalink)
Old 08-04-2010, 05:31 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
One of your first moves if you tackle this project, is to get a set of street tires and wheels under it (ex.- 235-75/15's ) so that it is a little closer to earth. Just while you work on it, you know?
Hey folks, I'm just a girl. 1948 chevy 3100 truck parts questions ace101966 Introduce Yourself 12 08-26-2013 07:52 AM
700r4 into 72 chevy truck... A few questions kookykrispy Transmission - Rearend 4 12-16-2008 02:21 PM
'77 Nova Sub-frame/rear end into '49 Chevy Fleetline??? jawiv Suspension - Brakes - Steering 3 05-26-2008 07:10 PM
1950 chevy Questions spikes_50 Body - Exterior 3 03-16-2003 10:56 PM
