Help with 9" ford rear brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2006, 03:35 PM
I have a 1969-1975 Ford 9 inch housing that i need to find brakes for. I don't necessarily need disc brakes, just something that isn't going to cost $500-900. If anyone knows of any good setups let me know. It will be installed on a '47 chevy panel truck.
Old 07-21-2006, 10:08 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
What is wrong with using the stock brakes?
Old 07-25-2006, 09:48 AM
S10xGN's Avatar
Gotta love a turbo!
Do a search on my username, I ran a post several months ago on my 11.75" C4 'Vette rear brake setup. I have less than $200 invested in the brakes themselves, not including the plumbing or M/C setup.
Russ
Old 07-25-2006, 10:29 AM
As a Moderator here and a Street rodder, I want to WELCOME YOU here ... to Hotrodders.com.
Everything for $300 or so ... off eBay ...
http://cgi.ebay.com/ebaymotors/9-For...QQcmdZViewItem
Be aware that there are different size bearing flanges ... and you will have to know which one you have ...
I myself have not used this eBay seller ... so you are on your own ...
Again WELCOME ...
Deuce ...
Ford 9" Rear End Gears youngc0@mchsi.com Transmission - Rearend 4 07-03-2006 11:39 AM
8" Ford Rear & Brakes GoodWood Transmission - Rearend 2 06-22-2006 03:45 PM
Converting Jag rear end to Ford 9" Jag Daddy Transmission - Rearend 5 12-25-2003 02:47 PM
ford 9" brakes joegaddy Suspension - Brakes - Steering 4 08-21-2002 07:03 AM
Ford 9" brakes Don Meyer Suspension - Brakes - Steering 5 07-16-2002 04:41 PM
