Help with the 9 inch Lincolin Versailles brakes. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-05-2012, 04:51 PM
Malibu man's Avatar
Last journal entry: My car.
I have a 9 inch Versailles rear in my 80 malibu,but the emergency brake has not been used in over 5 years,so the brakes are now out of adjustment( I checked the master cylinder,and the fluid was almost gone).
What I was wondering if I am able to pull the calipers and adjust them,or do I need to get rebuilt ones,and start over?
Old 01-06-2012, 08:44 PM
S10 Racer's Avatar
http://www.warsprints.com
Your post is kind of misleading. When you say calipers, that tells us that you have disk brakes on the rear. Those are not adjustable. If you have drum brakes, you have wheel cylinders, not calipers.
I try not to rebuild anything related to the braking system anymore. It's much less troublesome and sometimes cheaper to just buy new parts and replace them, even the drums or rotors.
11 inch brakes 14 inch wheel gearhead1964 Suspension - Brakes - Steering 3 07-09-2010 12:37 PM
Lincoln Versailles rear disc brakes doc bob Suspension - Brakes - Steering 4 10-22-2007 12:53 PM
versailles brakes, do i need the master cylinder? c_illes Suspension - Brakes - Steering 1 03-03-2007 08:23 PM
8.8 -9 inch brakes 347mustang Transmission - Rearend 0 01-25-2006 10:46 PM
