help--99 LS1 idler pully - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-19-2008, 08:20 AM
I have looked the net and can't find this, this LS1 is out of a transam 1999 model. it has 2 belts, on the side where the compressior is there's a idler pulley "guess thats what its called" thats slick on the part where the belt rides. no groves, none of the part stores has this, all the pulleys they have has groves. dealer wants 62 dollars and I thought I would try some of you guys before I go back to thedealer and order one-------Richie
Old 10-19-2008, 10:57 AM
try www.car-part.com
Shane
Old 10-19-2008, 01:26 PM
Thanks Shane, I looked 4 times and didn't see anything about engine pulleys. they did have a crank pulley listed-----------Richie
Old 10-19-2008, 02:14 PM
Silverfox031's Avatar
StreetRods & Customs Forever
Last journal entry: 37 Ford customized WildRod "Leilani"
Pulley LS1
I think this is what your looking for and I can let you have it for $20.00 + shipping to you.......if you want it.........Silverfox031@ Aol.Com
Name:	LS1  Belt tensioner.jpg
Old 10-19-2008, 03:18 PM
Thanks but thats not it, its on the same bracket that the compressor is on. right under it is the belt tension pully for the small belt on the compressior, two belts on this LS1. I bought it from a wrecking yard in or around Miami. guy said it was from a 99 firebird or maybe it was a transam-------Riche
it doesn't have its on bracket like pictured and has a star bolt that holds it on
Old 10-19-2008, 05:18 PM
3rdmember
here's what i'd do;
take it off and match it up at the parts store.
a real one, not bubble pack hell....
it's an idler pulley.
Old 10-19-2008, 05:53 PM
Bubble packed, its not--just crap.
I had the puley in my hand when I went to all the parts store's here--advance, autozone, carquest,o'reilly and none of them have this pully and don't have a listing for it.
I have the engine setting in the frame with no radiator so Im looking it straight on, it has a big funny looking washer on the back side and the front with a star bolt that holds it together. its on the same bracket that the compressor is attached to, has a tab sticking out where this pully slides on to, belt tension pulley is under it. it was sold to me as a 99 LS1--------Richie
Old 10-19-2008, 06:28 PM
3rdmember
is this it?
Name:	ac idler.gif
Old 10-19-2008, 07:49 PM
Hell yeah, its the one on top. any idea where I can find this on line--------Richie
Old 10-20-2008, 05:59 AM
3rdmember
i'm not finding a part # but i'd be off to the dealer with the pulley in hand or at least the picture.
geez, they used that setup on pickups, etc with 4.8's, 5.3's,6.0's.....
it CAN'T be that hard to find.
reason i say "off to the dealer" is that it may not be available aftermarket.
i've never had to replace one so....
the belt on the other hand, is usually crap and making noises
Old 10-20-2008, 08:52 AM
Thanks Tom, I found it on line last night and its ordered. it was around 22 dollars. RMS auto parts in Texas had it, they said it would be in the mail today-----thanks all you guys, Richie
Old 10-20-2008, 11:17 AM
47chevy's Avatar
Last journal entry: Here is the car after paint
The pickup accessory drive system is different than the f-bodys.
If you had the GM part # you can go to gm parts direct and get it cheaper.
c5 corvette vs. ls1 rear brake calipers FIREBIRDTONY Suspension - Brakes - Steering 1 04-06-2008 03:22 PM
LS1 in Camaro v LS1 in GTO? Longboard Engine 38 07-20-2006 10:47 PM
Ls1 with hilborn? Longboard Engine 19 10-09-2005 09:58 PM
camaro idler arm chevypunk Suspension - Brakes - Steering 1 08-16-2004 09:14 PM
Idler Arm help after front tire change 360Camaro Suspension - Brakes - Steering 1 12-28-2003 11:49 AM
