Help air compressor died?
Helllo my Porter-Cable CPL6025. died today, It is An oil-lube, belt-driven design with a 25-gallon horizontal tank. 8.6cfm @ 40psi, 6.8cfm @ 90psi.
My garage only has 120v hookups and it seems today there are no compressors to compare to this level of airflow at this 120V size. I used this compressor to do bodywork spray paint etc. and I was just able to get by with it. Anything with a smaller cfm rating won't work. My current compressor had a max psi rating of 135 and the pump kicked in at 110 psi The only improvement I can see from similar sized compressors made today is that they have a higher max psi say 175 and kick in at 145 psi. But they flow less cfm delivering 4.9 scfm at 40 psi and 4.7 scfm at 90 psi. *Does this higher Max psi make up for the lack in cfm??? Here is the new one I am looking at http://www.sears.com/shc/s/p_10153_1...ir+Compressors Here is the one I have that is discontinued http://www.air-compressors.com.ar/ai...B00004Z06D.htm Thanks I am supposed to pick one up tomorrow morning and am lost...... |
compressor
What died, pumps and motors are available.
The electric motor has two humps on top, some sort of solenoid under each cover but I am not sure what they are. The back hump started to spit out oil and smoke a little, it has two wires connecting to it. The motor was sucking more juice than usual and blowing 30 amp fuses in the fuse box. It started up and ran for maybe 30 seconds before blowing the fuse. I can't find any info on what this might be.....
Where does one find a capacitor. At any hardware store, radio shack or does it have to come from the manufacturer?
Thanks.. |
My 2 cents:
Your best bet to find a replacement capacitor will probably be an appliance repair store or a HVAC parts house. I personally have only had luck a handful of times finding a replacement capacitor locally. Like it was stated in a previous post, remove the cover and see if there is any info on the failed cap, i.e: the MFD # as well as voltage. If that's not available your next best bet is to purchase a new motor. This is more expensive that replacing a capacitor, but cheaper than buying a new compressor. Plus, you get to keep the cast iron compressor which is FAR superior than any oil less compressor pump (and much quieter too). I work in the commercial HVAC trade and see/have worked on many compressors - the oil less type ARE NOT made for continuous useage. The pistons are some plastic/nylon composite crap and the loose there ability to seal ( pump ) quite quickly if used in high cycle conditions. I have personally seen three failed oil less pumps (failed pistons w/blown rods in every case) in the last two months alone - however I have also seen MANY cast iron pumps that have years (thousands of operating hours) of use still chugging away. If you choose to keep the older compressor, change the oil with some fresh 30W non-detergent oil, drain the tank (open the drain valve on the bottom of the tank weekly to release the built up moisture in thank once it is under pressure) and clean or replace the air filter - your compressor will repay you by many more years of dependable use. Also, check this thread out - If anyone is looking for a new air compressor you might want to check this out. I don't know if there's a compressor available sized to fit your needs, but it might be worth a shot. Last edited by wild one; 12-30-2009 at 12:05 AM. |
That Sears compressor is a terrible choice! Nothing makes up for a lack of CFM, NOTHING!!! That compressor is just using the high pressure as a gimmick to make it look high performance when it is not, it has simply traded more CFM at a usable pressure for less CFM at a higher pressure. Sure you will store more (but much hotter due to this being a single stage) air in the tank but that is next to meaningless and is no more useful than a few more gallons of tank space at the lower pressure of your old compressor, certainly not the 60 gallons that Sears suggests but that would not help much anyway. The compressor you have is a much better design and if it is feasible to fix it you would be much better off, what part failed? Quote:
Not sure I would completely agree with you, IMO they are not made for usage at all!
Motor Start Capacitor
Hey Brandon, You will likely find what you need here;
http://www.grainger.com/Grainger/wwg...n_dim_search=1 olnolan |
Completely missed that! Sounds like a new capacitor is all you are going to need to put you back in business. |
It should go without saying, unplug that compressor before changing that capacitor. If it is hardwired open the breaker. BE SAFE and test for voltage with a DVM (digital volt meter) before working on it.
Vince |
CFM is what it's all about.
Fix you motor and you'll be back in bussiness.
If you buy another compressor be concended with the CFM moreso than the PSI it's what is needed for most of your tools. QUOTE=brandonA.]Helllo my Porter-Cable CPL6025. died today, It is An oil-lube, belt-driven design with a 25-gallon horizontal tank. 8.6cfm @ 40psi, 6.8cfm @ 90psi. My garage only has 120v hookups and it seems today there are no compressors to compare to this level of airflow at this 120V size. I used this compressor to do bodywork spray paint etc. and I was just able to get by with it. Anything with a smaller cfm rating won't work. My current compressor had a max psi rating of 135 and the pump kicked in at 110 psi The only improvement I can see from similar sized compressors made today is that they have a higher max psi say 175 and kick in at 145 psi. But they flow less cfm delivering 4.9 scfm at 40 psi and 4.7 scfm at 90 psi. *Does this higher Max psi make up for the lack in cfm??? Here is the new one I am looking at http://www.sears.com/shc/s/p_10153_1...ir+Compressors Here is the one I have that is discontinued http://www.air-compressors.com.ar/ai...B00004Z06D.htm Thanks I am supposed to pick one up tomorrow morning and am lost......[/QUOTE] |
Thanks for all the help guys. It was the capacitor on top of the motor. I had to drive 100 milles one way to get one but I feel better now!!! This forum rocks!!!!
Brandon |
| Recent Garage - Tools posts with photos |
| Martin Senour Tech Sheets? | unstable | Body - Exterior | 42 | 03-12-2011 09:09 PM |
| Turbo vs Supercharger - Write up!! | FastChevyTruck | Engine | 107 | 02-16-2011 12:18 PM |
| Runs Like Crap With Air Cleaner On - why? | leejoy | Engine | 30 | 11-16-2010 06:08 PM |
| larger compressor | gburgess2002 | Garage - Tools | 13 | 07-19-2009 09:36 AM |
| More on Orange Peel | KarKen | Body - Exterior | 36 | 03-22-2009 02:18 PM |
