Help with air/fuel wideband gauges - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2009, 04:02 AM
Andy79Z28's Avatar
I am looking to buy a wide band fuel ratio monitor. My car is carburetored. I am looking to have 2 gauges one for each exhaust.
I Would like to have only one gauge but looks like the choices are limited.
Comp cams has a system that monitors both exhausts.
What do you suggest?
Old 02-26-2009, 09:44 PM
75gmck25's Avatar
Wideband gauges are fairly expensive, so I don't think you want to buy two. However, a significant part of the expense is the O2 sensor, and you need two to monitor both sides.
I think you could switch a gauge between two sensors, as long as the sensors were always powered and heated so they would read accurately. However, an A/F ratio gauge is basically just a very accurate voltmeter, so added a switch and extra wiring might affect its readings.
Bruce
Air/Fuel Gauge tuning Mertz Engine 16 04-11-2008 09:19 PM
how to ajust carburetor with air/fuel ratio meter Ratoflic Engine 3 07-25-2005 10:12 AM
air/fuel gauges BanditT/A Engine 37 05-22-2005 03:43 PM
correct air/fuel ratio 68chevelle_ss Engine 17 09-08-2004 09:15 PM
Air/fuel ratio meter al37ford Engine 14 08-01-2004 02:46 PM
