Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help with another 355 build!
Old 09-04-2013, 04:06 AM
jokerZ71's Avatar
jokerZ71 jokerZ71 is offline
Wrench Turner
If you don't know the part# for the pistons used,I would ck to see how far down inthe cylinder the pistons are.Hopefully they are not the "rebuilders pistons" w/ a short 1.54" pin hgt.Also,are you using the PCM & engine/trans mgmt from the 97?If using aftermarket EFI system,most controllers that come with them won't control the 4L60E.The 0411 controller from a 99 up would be the better option.Better tuning options & capability & you can control engine & trans w/ 1 controller.
