Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help with another 355 build!
Old 09-04-2013, 04:21 AM
jokerZ71's Avatar
jokerZ71 jokerZ71 is offline
Wrench Turner
Use 1 of the online DCR calculators to play around with different head chamber sizes & cams to see what your CR would be with different combos.For instance,with flat tops & a 64cc head,you are gonna be in the neighborhood of 10:1 SCR which would be borderline w/ iron heads,but,fine w/ aluminum.Cam choice will also play a role in your final effective CR (DCR) as well. Comp cams XR264HR would be a good choice for good streetable cam depending on what you HP goals are.IIRC,the stock EFI can support approx 400 HP.
