Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help with another 355 build!
Old 09-04-2013, 12:24 PM
BaySox1 BaySox1 is offline
Originally Posted by F-BIRD'88 View Post
If this is a 19971 350 LT1 Gen II motor you can only use a GENII style head on it.
LT1 or Lt4 motor. Where are the stock heads for this motor? Stock EFI intake manifold etc?
Yes, I got the entire engine (with accessories still on it) , trans, wiring harness and computer. It was an LT1 aluminum heads, gear driven water pump etc. I believe the heads are small valve and would need to be reworked to be of any rear use. I think that the benefits of a new set would outweigh what I would get by having my old heads redone. RIGHT?????
