Help with another 355 build! - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-04-2013, 05:22 PM
jokerZ71's Avatar
Wrench Turner
You will need a Gen2 head for either LT1 or LT4.I would use the smallest chamber volume I could get as close to your stock size.Even a 64cc chamber is gonna give up some compression.Your stock heads were 58cc.Camshaft selection is gonna be critical to not lose even more compression due to larger cams with late IVC points bleeding cylinder psi off.As far as port size,IMO,the 195cc would be good.You currently have 185cc intake ports.I'd rather have a 2nd opinion on that that tho to confirm.I'm not completely up to par on benefits & effects of the different port sizes & how they apply.Choose your head 1st,so you know what your SCR will be,then choose a camshaft with specs that will provide you with the proper timing events,specs,to your particular combo that will provide you with an optimum DCR.
  #17 (permalink)
Old 09-04-2013, 05:55 PM
jokerZ71's Avatar
Wrench Turner
While shopping & comparing heads & flow rates each 1,don't get hung up on maximum advertised flow.Some heads advertise the max flow @ high lifts.Compare flow across the board @ low lift,mid lift.If a heads best flow is only achieved @ max lift,that's the only time you will see the benefits.Your cam spends most of it's time @ low to mid lifts.You want a head that has good flow across the entire lift.Not just @ max lift.
  #18 (permalink)
Old 09-04-2013, 07:32 PM
jokerZ71's Avatar
Wrench Turner
Your intake is a dry flow.it doesn't convey air & fuel as a carb setup.Even so,cleaning up any casting flash,mismatch,or,irregularites is always a good thing.
  #19 (permalink)
Old 09-05-2013, 10:16 AM
For all intents and purposes, if I stick to Brodix, Edelbrock or Pro-Filer, shouldn't I be OK?
I'm looking at these heads from Pro-Filer:
SBC 23 Degree Cylinder Head, 11/32 Guides & Steel Seats
Intake Port Size: 195cc Intake Ports
Chamber Size: 70cc As Cast Chamber
Spark Plug Orientation: Angle Plug
Intake Valves: 2.02/1.600 Valves
Spring Package: Opt 92 .550 Lift,1.250 Single Springs, AL Retainers, Keepers Assembled ADD $50
Casting Style: Standard Cooling
Any thoughts?
  #20 (permalink)
Old 09-05-2013, 02:42 PM
Originally Posted by F-BIRD'88 View Post
You cannot use a standard GEN I style head on a Gen II motor (LT1, LT4)
and the chamber is too big unless you will be supercharging it.
AFR makes a good Gen II head for this motor. Hi port heads need the LT4 intake
Yea, I undestand that 92-97 LT1 is different. What size chambers should I be looking for? Something close to to 56 CC?
  #21 (permalink)
Old 09-05-2013, 04:44 PM
jokerZ71's Avatar
Wrench Turner
You have 54cc on your stock head.You wanna stay close to that to keep from losing compression.The E'brock Performers have 54cc & 170cc intake port vs your stock 185cc.They flow 242 cfm @ .500 lift.Lower lift #'s are ok.You also have Dart Pro 1's, AFR's.IDK what your budget is for heads.The E'brocks will support your 400HP goal,but,that would be about all.Most aftermarket LT1/LT4 heads have 54 to 58 cc chambers.IDK how the 170cc intake ports vs your stock 185cc would effect things.F'bird can maybe explain that better than I can.
  #22 (permalink)
Old 09-05-2013, 08:45 PM
jokerZ71's Avatar
Wrench Turner
This Trick Flow head looks like to me it would be a good candidate. #TFS30410008-M54. $1500. Not bad for a CNC chamber head. The TFS-30410010 is also good except it has 62cc chambers & since your already an extra .020 in the hole,you will lose some CR. $1460.
  #23 (permalink)
Old 09-05-2013, 09:01 PM
Banned
For 400hp stock lt1 heads will work fine though a little port work can help.
  #24 (permalink)
Old 09-05-2013, 09:11 PM
jokerZ71's Avatar
Wrench Turner
I wasn't sure if they would or not.I was basing on the fact that Vortecs flow 230Ish & are spose to support 400.The stock LT1's flow around 212.I thought they may fall a little short.
  #25 (permalink)
Old 09-05-2013, 09:15 PM
Banned
With a good valve job and a little porting they will do quite well.
  #26 (permalink)
Old 09-06-2013, 05:11 AM
OK---you guys got me considering using my stock heads. SO..... the engine had 170,000 hard miles on it. The owner really didn't believe in preventive maintenance ie. oil changes etc. I don't have the skills, or equipment, to do my own head work. If my heads need EVERYTHING, plus the performance work, angle valve job, porting etc., is buying new heads a better option or just get the old heads done? Any limitations on my cam selection by using my old heads?
  #27 (permalink)
Old 09-06-2013, 05:49 AM
Banned
No limits on the cam. I'd send them to headbytes to get them redone, best value for the money.
Headbytes.com
You can try local too but I don't know what the prices will be.
  #28 (permalink)
Old 09-06-2013, 06:28 AM
jokerZ71's Avatar
Wrench Turner
wondering if the stock injectors will be OK,or,if he may need to go up a size,or,2?
  #29 (permalink)
Old 09-06-2013, 07:00 AM
jokerZ71's Avatar
Wrench Turner
he has the short pin hgt pistons,so,he's lost some amount of CR to begin with.
  #30 (permalink)
Old 09-06-2013, 08:41 AM
jokerZ71's Avatar
Wrench Turner
The guy that AP mentioned @ Headbytes seems like he has some good stuff goin on.I would give him a call if you wanna rework your stockers.He's not very far from me,so,I'm definitely gonna give him a call.Decent prices if he does what he says.Shipping will prolly be the deal breaker tho.IDK if you'll save anything by the time you ship a set of heads both ways.
355 build??'s about compression and build impalaman355 Engine 5 06-06-2011 10:20 AM
355 build corkym Engine 16 10-19-2010 06:11 PM
355 build help old76c10 Engine 10 08-25-2009 07:07 PM
355 build jgh64pkup Hotrodding Basics 19 03-20-2009 10:53 AM
355 build Titanium Engine 3 08-28-2007 02:01 PM
