Help with a arm - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2009, 10:12 PM
Help with a arm
I need help with narrowing a arms on a 85 chevy truck, any one know who does this kind of work or how to do this, i only need to go 1 to 1.5 inches narrower. thanks
Old 05-26-2009, 11:08 PM
powerrodsmike's Avatar
Wiki Edits: 161
What are you trying to accomplish?
Narrowing A arms will cause more problems than they will fix.
Later, mikey
BE different....ACT normal.
Old 05-27-2009, 10:22 PM
I put a 51 chevy truck on a chevy 85 frame with a 5 inch lowering kit, and the front tires stick out 1 inch, and im afraid the tire will hit the fender if i hit a pot hole , if narrowing the a arms is a bad idea then i will take the lowering kit off and go with a 3 inch on instead. what do you think, any ideas!!
Old 05-27-2009, 10:25 PM
ericnova72's Avatar
More for Less Racer
Are you thinking of narrowing both the upper and the lower, or just the upper because it is causing the tire to lean outward at the top?
Old 05-27-2009, 10:31 PM
I would narrow both upper and lower
Old 05-27-2009, 10:38 PM
ericnova72's Avatar
More for Less Racer
Back to what Mikey said, very hard to do and keep good suspension geometry.
Old 05-27-2009, 10:39 PM
ericnova72's Avatar
More for Less Racer
You might check with companies that specialize in lowering the 73-87 trucks for tubular control arms.
Old 05-27-2009, 10:42 PM
Do you know of any i have looked with out any luck.
Old 05-27-2009, 10:47 PM
ericnova72's Avatar
More for Less Racer
Not offhand, check your local magazine rack for Truckin' or Sport Truck or a lowrider specific magazine.
Old 05-27-2009, 10:50 PM
Thanks i will take look
Old 05-28-2009, 05:59 AM
Different wheels ?More offset might get ya just enough.
Valve Lash adjustment hiball Engine 36 05-11-2009 11:12 AM
arm rest,door panels NEW INTERIORS Interior 4 12-27-2007 09:09 PM
Custom Pitman Arm Tribal Suspension - Brakes - Steering 7 07-17-2007 05:24 PM
Lower control arm hits Granada rotor on stock Mus II suspension Darkman270 Suspension - Brakes - Steering 8 07-25-2006 02:26 PM
upper a arm rubbing RodFather Suspension - Brakes - Steering 5 12-07-2004 07:05 AM
