Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - HELP WITH B&M SHIFT KIT/TURBO 350
  #16 (permalink)
Old 03-24-2006, 06:19 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
The t-350 valve body is cast iron. Warping the v-body is difficult. The threads would pull from the aluminum case first .
An inch pound torque wrench would be handy. Or the "gentle touch" as someone posted. I have not used a torque wrench on a t-350 in years
I would run a large flat file across the v-body to check for high spots.
Lets keep a level head when responding to information posted on this board.
thanks,
Tony
