help on back-half project. can't find aluminum wheel tub liner - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2006, 09:42 AM
been searching the net for plastic (or?) liners for the aluminum tubs on my back-half project and can't find em... anybody got any links / leads ? I remember seeing an ad in the back of old national dragster but of course I don't have the issue. any help would be greatly appreciated. thanks.
Old 08-18-2006, 10:01 AM
astroracer's Avatar
Line the tubs with a second layer of aluminum or galvinized steel sheet. Cut a piece wide enough to cover the tread pattern and then silicone or rivet the liner in place. Leave a 1/4" air gap between the inner and outer as a buffer for stone dings.
Galvinized works well for this as it is very cheap from an HVAC place and it is a bit tougher then the aluminum.
Mark
Old 08-18-2006, 12:45 PM
T buckets rule
Summit has them.
http://store.summitracing.com/egnsea...s=false&N=+115
I would use the steel ones. The aluminum ones will dent from every little rock that hits them. Just my 2 cents. Its your car build it the way ya want to.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Pro Topline Heads surfinca Engine 33 12-28-2008 11:37 AM
New Guy Randy Ferguson Hotrodders' Lounge 11 03-09-2004 01:06 AM
How much comp?? BCNU 64 nova Engine 23 12-18-2003 11:34 AM
steering wheel bearing for 72 chevy any one know where to find one? 72 chevy elcamino Engine 2 10-13-2002 05:18 PM
