Help with the basics,top coat clear coat - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2006, 05:53 PM
chevellenut's Avatar
I was wondering if you guys could give me the rundown on painting using basecoat clearcoat.The base coat just mixes with thinner no hardner Right or wrong?IF so how much hardner.Also how long do you wait to put the clear on to it.Till it dryes or at a certain amount of tackyness.The hardner goes in the clear coat Right?
Old 04-08-2006, 06:11 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
You should be getting from your jobber the complete rundown on using the products he supplies..
To answer.."It depends" on how the products you are using are formulated and intended to be applied..
Not much of an answer..
Sam
Old 04-08-2006, 06:19 PM
Wiki Edits: 49
Each paint supplier will have product sheets or "P" sheets that give all that information for each paint line they carry. Today's automotive paints are a miracle of modern chemistry and because of that mixing of paints, reducers, hardeners etc. must follow strict guidelines for each product. It's not a big deal but each paint line is different and has a slightly different chemistry so you just can't mix and match. Follow the "P" sheets and you won't have a problem.
Old 04-08-2006, 07:32 PM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
A simple run down for you as a generalization only:
1. Base mixes 1:1 with reducer not thinner... thinner is for lacquer and that is like using an apple computer from 1980 some bases may mix 1:1.5 dpends on base
2. You can add hardner to your base if you so choose.. this can be done at 5% max for the overall total amount in the already mixed cup
3. Clear Coats require hardner, all of them that are urethane, they mix various ways, from 1:1 all the way to 4:1 and some Euro clears have an even different mix ratio.. Pretty straight foward and simple
4. Primers also use a hardner.. that is the urethane primers.. dont waste time or money on lacquer primer.. we have already discussed why there
Lastly go here and read the Basics of Basics from MartinSr and that should clear up allot
Old 04-09-2006, 04:45 AM
adtkart@aol.com
Like has been said, check the P pages. Everything will be in there, from the mixing ratio, to the proper item to mix with it, to the pressure to spray it at. It should also give you an idea of the "Flash" and "recoat" times. Also keep in mind that the times are "general" in that temp and humidity make a difference.
Aaron
"Basic of Basics" How do you properly apply filler? Centerline Body - Exterior 2 02-10-2006 12:22 AM
Clear coat repair don't match Ratchet Body - Exterior 31 12-13-2005 10:11 PM
base coat clear coat wally Body - Exterior 8 12-12-2005 06:44 PM
To clear coat or not to clear coat Jeepster Body - Exterior 2 10-24-2005 06:27 AM
Can I Spray Clear Coat Over Clear Coat ??? STATUTORY GRAPE Body - Exterior 2 10-07-2003 09:09 AM
