Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help with battery draining gremlins, 83 pontiac with 305
Old 02-29-2012, 11:42 AM
boothboy boothboy is offline
Try checking it out the old fashion way. Disconnect the pos battery cable. Connect a test light in series between the batt post and the cable end. If the light lights you have a draw. Start pulling fuses until the light does out. When that happens you will know which circuit to check out. Remember when you open the door to get inside you activate the interior light circuit.You might have to pull the door jam switch out so you check out the remaining circuits.
