Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help with battery draining gremlins, 83 pontiac with 305
Old 03-04-2012, 09:44 AM
EOD Guy's Avatar
EOD Guy EOD Guy is online now
Reason for the connector advice.......... as happens sometimes, things get damaged and spade connectors or after market pig tails are used in place of OEM connectors, and it's very easy to switch the two.......I've seen it happen many times and it has the exact same symptoms as the OP described.
