Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help Bleeding new Brake System
Old 08-18-2012, 06:36 PM
scholman scholman is offline
tc33,
You may need to use a pressure bleeder. If you can not find one then make one using a hudson type sprayer. Instead of weed killer use brake fluid. The hardest part is a plate for the reservoir that will not leak. Pump the sprayer a few times and wire the trigger down. Then open the bleeder valves one at a time until you have good pedal. BTW are all four corners disc?
