Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help Bleeding new Brake System
Old 08-18-2012, 11:10 PM
tc33's Avatar
tc33 tc33 is offline
Stuck in the 30's
Last journal entry: Where it came from and how I got there - a short Summary
OK Guys, I'll comment on all your comments...
Discs are at all four corners
Prop valve is open all the way to prevent any restrictions. I read that post too...
All bleeder valves are at the top of all calipers.
I'm pretty sure the rear circuit is air free. Good flow out of both sides.
I think the air bubble is in the front circuit since I had to replace a line and got lots of air from the passenger side caliper before fluid. Did the driver side and got some air before fluid. Can't be 100% sure but I'll do all corners until I stop the pedal from hitting the floor.
I love trial and error and error and error. Oh well I don't have anything better to do tomorrow.
Gravity bleed: unmounting the calipers or using the jack are options to consider but alot of work. I'll keep those as a last resort. The car is up on a drive on lift.
I like the vacuum bleed suggestion. Found one at Harbor Freight for $23. I don't have a hudson sprayer but thanx for that suggestion.
Will keep you advised.
