Help Bleeding new Brake System
Hey All,
Here's my situation... I haven't got the motor running yet. Keep that in mind for the end of this message. New brakes, discs, on all four corners Frame mounted master cylinder w/booster, remote reservoirs All new lines, proportioning valve on the rear circuit Residual valves on front and rear circuits I've tested all valves to be sure they are installed correctly. I bench bled the master cylinder and tested it for good pressure and no bypass leaks I've been trying to bleed the system to get a good high pedal but no luck. I'm using DOT 3 synthetic fluid. I know that synthetic usually gives a soft pedal but this soft???? I start bleeding and the farthest point both front and rear. After bleeding the system over and over again I get a good shot of fluid, no air, from each caliper but I can never get the pedal higher than an inch or two off the floor. After bleeding, the first pedal pump usually hits the floor then I can pump it up to the inch or two height. Once I get the motor running, will the vacuum booster help raise the pedal higher? Any suggestions will help in my frustration. Thanx in advance.
Here is the master cylinder I have Master Power Brakes - REMOTE FILL POWER MASTER CYLINDER WITH PLASTIC RESERVOIR
Based on your response I went out and measured the pedal heights from the floor... 6 inches high before pumping it. first pump, it hits the floor after a couple of pumps it builds resistance and stops about 2 inches from the floor when released it goes back to 6 inches from the floor... |
First of all, thanks for sharing that link. It gave me some ideas for a problem I am working with...
Anyway, a 1" bore should be big enough. But, each application is different. You may need to go bigger. When I did mine, I tried a few before I got it right. But, I was working with cheaper parts. The fact that you have to pump it up makes me think somethings up with the residual valves. Or still a possibility there may be some air still in the lines. That lower MC doesn't make it easy Was this a kit or are you putting it together yourself? If it is a kit, is there a tech phone number you can call? Sorry I'm not being very helpful here. |
You are being helpful!!!
I also think it is air in the line(s) but I've never had to deal with this for as long as it has taken. I just wanted to have a sanity check. The MC and booster came together. The calipers are GM with 11" rotors. I'll try bleeding some more to see if there is a stubborn bubble stuck in there somewhere. Then go to spend more bucks on a bigger bore. Again, thanx for the help. |
tc33,
You may need to use a pressure bleeder. If you can not find one then make one using a hudson type sprayer. Instead of weed killer use brake fluid. The hardest part is a plate for the reservoir that will not leak. Pump the sprayer a few times and wire the trigger down. Then open the bleeder valves one at a time until you have good pedal. BTW are all four corners disc? |
While mine is a disk/drum system, it's pretty much the same as yours. I used a vacuum bleeder, took quite a while to get all the air out but it sure did the job far better [IMO] than pumping & releasing !!
dave p.s. Did you mean DOT 5 ??..... no problem , that's what's been in mine for 12 years. |
Does anyone know if the proportioning valve can cause problems with the bleeding? I did a search for low mounted master cylinder bleeding and one of the posts mentioned this issue. I don't run a prop valve in mine so I didn't run into this problem.
One of the techniques I use is open the bleed valve on the caliper and let the system gravity bleed before I start the normal "press and release" bleeding. But, I have a high mounted MC.
So, I was doing some more reading on low mounted MC's and I read some posts where guys were doing one of two things to replicate the gravity bleed: 1) jack up one end of the car to make the MC higher than the calipers you're bleeding; or, 2) Unbolt the calipers and let them hang lower than the MC. Two more questions...Are there any places in the line where an air bubble might get caught and not get pushed through? Also, are your calipers mounted with the bleed valve at the top? |
OK Guys, I'll comment on all your comments...
Discs are at all four corners Prop valve is open all the way to prevent any restrictions. I read that post too... All bleeder valves are at the top of all calipers. I'm pretty sure the rear circuit is air free. Good flow out of both sides. I think the air bubble is in the front circuit since I had to replace a line and got lots of air from the passenger side caliper before fluid. Did the driver side and got some air before fluid. Can't be 100% sure but I'll do all corners until I stop the pedal from hitting the floor. I love trial and error and error and error. Oh well I don't have anything better to do tomorrow. Gravity bleed: unmounting the calipers or using the jack are options to consider but alot of work. I'll keep those as a last resort. The car is up on a drive on lift. I like the vacuum bleed suggestion. Found one at Harbor Freight for $23. I don't have a hudson sprayer but thanx for that suggestion. Will keep you advised. |
Help bleeding new brake system
With a new brake system you need a vacuum pump or brake pressure bleeder more than ever. I replaced the master cylinder and brake lines on my Camaro. I followed the instructions on making this power bleeder and it works great. I went to Advance Auto Parts and bought a new master cylinder cap. You could get one cheaper off a wrecked car. Here are the instructions. The DIY $20 brake bleeder
| Bleeding Air from system with adj valve. | 67Mustang Al. | Suspension - Brakes - Steering | 30 | 02-07-2011 03:53 AM |
| 96 S10 clutch system- air -bleeding? | 31chevy | Transmission - Rearend | 2 | 03-20-2010 07:04 PM |
| bleeding new brake system | dar130 | Suspension - Brakes - Steering | 5 | 04-28-2008 10:48 PM |
| Bleeding Saginaw system | HotRod60 | Suspension - Brakes - Steering | 2 | 03-23-2008 01:53 PM |
| Air bag system leaking/bleeding out | artillerystevens | Suspension - Brakes - Steering | 5 | 10-21-2007 12:14 PM |
