Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help with block sanding clearcoat runs SPI clear
Old 05-23-2012, 10:16 AM
cyclopsblown34's Avatar
cyclopsblown34 cyclopsblown34 is offline
Colorsanding painter
I use the razor blade method but bend the blade just a touch so the corners are up and away from the material. Another method I've heard mentioned is taping alongside the run on both sides and then wetsanding the run til you start to cut paper, then go to finer paper and wetsand checking frequently as Martin said.
