Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help with block sanding clearcoat runs SPI clear
Old 05-25-2012, 05:26 AM
deadbodyman's Avatar
deadbodyman deadbodyman is online now
Wiki Edits: 11
I have never gotten the hang of that, but damn it works good as I have seen others do. I had a guy screw up a tail lamp yesterday and he scraped off all the funk with a razor and then polished it to perfection.
The whole trick to using a razor is to put a slight bend in the blade so the corners dont dig in....believe it or not it took me years to figur this out,I tried rounding the edges and everything this works best with soft clear then let the run cure a day and sand with 600 on a wood block 3/4' x 3/4" x 2" long ..not that I ever got a run but I do get an occational Flow indicator..
