Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help with block sanding clearcoat runs SPI clear
Old 05-25-2012, 08:05 AM
cyclopsblown34's Avatar
cyclopsblown34 cyclopsblown34 is offline
Colorsanding painter
Originally Posted by deadbodyman
The whole trick to using a razor is to put a slight bend in the blade so the corners dont dig in....believe it or not it took me years to figur this out,I tried rounding the edges and everything this works best with soft clear then let the run cure a day and sand with 600 on a wood block 3/4' x 3/4" x 2" long ..not that I ever got a run but I do get an occational Flow indicator..
I sign them occasionally with a flow indicator as well. Did a flow coat last night on the SS Giallo Fly on my son's hood...wow!
