help with brake system - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2007, 05:40 AM
I need help with my brake system. I want to make sure its safe. I have an S-10 that's used just for drag racing. It has the stock power brake master cylinder , stock disk brakes in the front and a ford 9" with drums in the rear. I was thinking about doing away with the power brake master due to it needing vacuum and replacing it with something like a 67 vette manual master. What do you guys think? will this be a good combo? Will I need a proportioning valve?
Old 10-24-2007, 08:26 AM
pepi's Avatar
How’s that hopey-changey thing
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
I would not see a problem with your idea, I think you already have the proportioning valve covered running a duel brake system, disc/drum. Just plumb in the manual master.
Old 10-24-2007, 08:40 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
I assume that this is a quick S10
so along with the master cyl. I would
also upgrade the stock disc & calipers,
it's no fun when you end up in the
stop pit at the end of the track.
Take care,
rich
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
Charging system info............... poncho62 Electrical 11 11-26-2005 08:53 PM
Advantages -pitfalls of relocating parking brake to tranny hump Ripped Suspension - Brakes - Steering 1 09-01-2005 01:47 PM
Hydro Boost brake system BLOWN 1100 Suspension - Brakes - Steering 1 07-12-2004 12:23 PM
Regretting using silicone fluid - advice? Limey Simon Suspension - Brakes - Steering 3 04-30-2003 06:07 AM
