HELP brakes not releasing all the way
installed a complete drum disc conversion including lines
after install I had about 2inches travel in the pedal and brakes released fine. first time out with the car the fronts wont release all the way. I can turn them with a bit of effort but they seem to be dragging now and the pedal is hard and super sensitive. on assembly i adjusted the booster rod to 5 3/4 inches to the clevis hole. I used the new booster to M/C rod (short) im also wondering if the combo valve isnt releasing the fronts? all parts are brand new (that dont mean they are good though) |
never mind I found out the booster/master pushrod is 1/8 too long.
| All times are GMT -6. The time now is 04:13 AM. |
