HELP brakes not releasing all the way - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2007, 10:47 AM
dawg's Avatar
NAVY VETERAN
installed a complete drum disc conversion including lines
after install I had about 2inches travel in the pedal and brakes released fine.
first time out with the car the fronts wont release all the way.
I can turn them with a bit of effort but they seem to be dragging now and the pedal is hard and super sensitive.
on assembly i adjusted the booster rod to 5 3/4 inches to the clevis hole.
I used the new booster to M/C rod (short)
im also wondering if the combo valve isnt releasing the fronts?
all parts are brand new (that dont mean they are good though)
Old 04-21-2007, 12:18 PM
dawg's Avatar
NAVY VETERAN
never mind I found out the booster/master pushrod is 1/8 too long.
« Oops.... | steering »
disk brakes conversion no pressure to back brakes shiner Suspension - Brakes - Steering 10 01-24-2011 11:09 AM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 06:29 PM
Brakes DoubleVision Suspension - Brakes - Steering 2 11-11-2005 01:51 PM
G body with manual brakes - it works! - pics dh79 Suspension - Brakes - Steering 7 08-27-2005 10:55 PM
Brakes locking up in non ABS system nprfan Suspension - Brakes - Steering 9 08-24-2005 12:37 PM
