Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help! Brakes wont build pressure... they did before I replaced the lines?
Old 06-05-2011, 03:22 PM
T-bucket23's Avatar
T-bucket23 T-bucket23 is offline
Wiki Edits: 26
Originally Posted by honster919
Just replaced the front rubber brake lines on my 58 Buick Super 2 door. Had pressure... now mush pedal forever. We were bleeding the brakes for like 10 minutes solid. Very minor pressure, had fluid at the end of the line. I know sometimes it take a while to push all lost fluid back to the ends of the line. What do yall think the max time limit of bleeding the brakes would be. I'm probably not being patient enough and the wifes leg is getting tired of pumping the brake.
Do not pump the pedal.
1 Open the bleeder
2 push pedal 3/4 way down,
3 close bleeder,
4 release pedal,
5 repeat from 1 until there is no air.
Pumping the pedal does nothing but stir up the air and if you push it all the way to the floor you run the risk of damaging the internals of the master.
You may want to be sure all your connections are tight. I have seem them suck air with little to no fluid leakage.
Edit: If it is the original single master cylinder you may also need to bleed the rears as it is all one system
Chet
