Help! Brakes wont build pressure... they did before I replaced the lines? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2011, 12:11 PM
Just replaced the front rubber brake lines on my 58 Buick Super 2 door. Had pressure... now mush pedal forever. We were bleeding the brakes for like 10 minutes solid. Very minor pressure, had fluid at the end of the line. I know sometimes it take a while to push all lost fluid back to the ends of the line. What do yall think the max time limit of bleeding the brakes would be. I'm probably not being patient enough and the wifes leg is getting tired of pumping the brake.
Old 06-05-2011, 12:47 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Just fill the resevoir, open the bleeder and let it drip for 15 min. keeping an eye of the fluid level.
Old 06-05-2011, 03:22 PM
T-bucket23's Avatar
Wiki Edits: 26
Do not pump the pedal.
1 Open the bleeder
2 push pedal 3/4 way down,
3 close bleeder,
4 release pedal,
5 repeat from 1 until there is no air.
Pumping the pedal does nothing but stir up the air and if you push it all the way to the floor you run the risk of damaging the internals of the master.
You may want to be sure all your connections are tight. I have seem them suck air with little to no fluid leakage.
Edit: If it is the original single master cylinder you may also need to bleed the rears as it is all one system
Chet
Old 06-05-2011, 05:15 PM
if bleeding the brakes dont work change your master cilinder
Old 06-05-2011, 05:55 PM
el pollo's Avatar
It's shady under this tree...
Just get a vacuum bleeder kit. Fill the cylinder, mash the pedal slowly down and hold it, hook the vacuum bleeder tool to the open bleeder and suck the fluid into the lines and calipers/wheel cylinder. When the cylinder is almost empty, fill it back up and repeat.
Old 06-06-2011, 08:03 AM
Thanks for the tips. I am a novice builder with a solid start.
Old 06-06-2011, 08:23 AM
RippinRon's Avatar
Start at the wheel that is furthest away from the master (right rear). Then do the next closest and so on. Even though you didn't touch the rear there could be air in them.
disk brakes conversion no pressure to back brakes shiner Suspension - Brakes - Steering 10 01-24-2011 11:09 AM
replaced intake gasket, now wont idle blue400 Engine 10 09-19-2010 10:13 AM
replaced TC now it wont go into any gears. Chevy350Sb Transmission - Rearend 39 11-22-2009 06:37 AM
Replaced Brushes & replaced battery terminals 78novaman Electrical 1 10-01-2006 07:39 PM
Brake lines how often should they be replaced? Jag Daddy Suspension - Brakes - Steering 1 03-18-2003 04:56 AM
