help building 383
hey im looking to start building my 383 for my 65 nova.
Im using a 4 bolt block im unsure about what rotating assembly to use i plan on buying a set of brodix IK 200 heads. what im curious about is what kind of cam should i use and what should i be looking for in a rotating assembly? also should i use a t350 or a t400? im planning on this being a street strip car |
More information needed. How much power do you want to make, torque, gearing, budget.
im looking to make under 500 horses (450?) and around the same torque ive yet to put gears in (empty third member) but was thinking around 323 so its still streetable and im looking to keep it around $3500
what would you suggest that could still be driven a few miles on the free way (25 max)
9.5:1 to 10.0:1 static compression ratio, camshaft 230 @0.050", 3.90:1 to 4.11:1 rear gear.
how would 3.70:1 run its in a ford 9 inch with cadillac rear drums
| new and need help building 383 stroker | enygma500 | Engine | 10 | 02-10-2013 01:24 PM |
| Look for info an building a 383 stroker | Cllmewish | Hotrodding Basics | 16 | 12-28-2012 03:31 AM |
| Designs for building a 700ish HP 383 stroker | cam383aro | Engine | 54 | 07-10-2012 12:24 AM |
| Building a 383 stroker | holstonallen | Engine | 3 | 06-04-2007 09:55 PM |
| building a 383. what cylinder heads? | Troll_Killer | Engine | 26 | 11-27-2004 07:32 PM |
